ENA Set of 4 Ignition Coil Pack Compatible with Nissan 2002 2003 2004 2005 2006 Sentra 1.8L L4 Replacement for UF351 22448-6N015 22448-6N011 22433-6N015 C1397
Technical Details
- Manufacturer - This one
- Brand - This one
- Model -Ignition coil
- Item Weight - 5 ounces
- Product Dimensions - 9.5 x 3.5 x 6.5 inches
- Item model number - 22448-6N015 22448-6N011 C1397 UF351
- Is Discontinued By Manufacturer- No
- Exterior- Textured
- Manufacturer Part Number- ENAIC3315804
- OEM Part Number -22448-6N015 22433-6N015 22448-6N011, 5C1394 50078 C1397 UF351, 5C1394, E1048, E381, 52-1745, IC481, 22433-6N015, 22448-6N015, UF-351, UF-548, UF351 / 224486N015 / 22448-6N015 / 224486N011 22448-6N011 / 224336N015 / B335
- Ignition Coils are engineered for original equipment and replacement applications. Every component either matches or improves on the OE design to ensure fast and easy installation with superior performance and reliability
- Reduces common ignition coil issues such as; no/hard start, long crank time, misfires, lack of power, inconsistent transmission shifts, poor fuel economy, check engine light illumination
- Designed and manufactured to operate reliably under all operating conditions and throughout the entire engine speed range for peak engine performance
- products are designed to meet or exceed OE specifications in form, fit and function
- Lifetime Warranty - Please use enter your vehicle in your Amazon Garage above to see if this part is compatible with your vehicle
product link - https://amzn.to/3glMQi4
buy now link click - https://amzn.to/3glMQi4
THANK YOU
