Discussion Starter #2 (Edited)
I should have placed the listing in the "For Sale" section, but the new Nissan parts do apply to these Altimas.
The parts remain available as we start the new year.
If you know anyone in the MD or VA area who can use these, please let them know. I'd be willing to meet them with the parts if within a reasonable driving distance. Otherwise, pickup is preferred.
All parts are brand new Nissan in original boxes and packagings.
Discussion Starter #3
Feb update:
The new genuine OEM Nissan Altima parts remain available.
The craigslist link changed (why original link not showing now).
Just search craigslist VA fredericksburg: New Nissan Altima Parts
or
100 New Nissan Altima Parts
for pics and full parts listing.
Quite the list
Air cleaner housing clips 16598-86G0A
Air cleaner housing cover bolts (engine cover bolts) 16122-5Y70A
Air intake duct assy 16576-JA000
Battery top hold-down bracket 24420-JA000
Battery positive terminal connector 24340-JA74A
Battery fusible link holder 24380-JA00A
Brake - brake booster vacuum hose 47474-JA000
Brake - brake booster vacuum hose with check valve 47471-JA000
Brake - Front brake hardware kit D1080-JA00A
Brake - Front brake torque member bolts 08044-4501A
Brake - Front brake torque member bolts washers 41044-6P01B
Brake - Front caliper pin bolts 44141-JA00A
Brake - Front caliper pin bolts - lower 44140-JA00A
Brake - Front caliper pin bolts - upper 44139-JA00A
Brake - Rear brake pads D4060-JA00J
Brake - Rear brake hardware kit D4080-JA01B
Brake - Rear caliper pin bolts - upper and lower 44141&0-JA01A
Brake - Rear brake torque member bolts washers 01311-01251
Coolant CTS coolant temp sensor 22630-JA10A
Coolant housing gasket 13050-3Z000
Coolant housing gasket 11062-3Z000
Coolant housing gasket 21014-3Z000
Coolant hose - heater inlet hose 92400-ZX00A
Coolant hose - heater outlet hose 92410-JA000
Coolant hose - clamps for heater inlet + outlet hose 01558-00521
Coolant hose - radiator inlet hose assy (upper hose) 21501-9HA0A
Note this includes the entire assy: top 2 hoses + radiator cap housing + port to reservoir
Coolant hose - radiator outlet hose (lower hose) 21503-9HA0A
Coolant hose - upper radiator port to reservoir 21741-JA00A
Coolant hose - coolant housing 14056-JA00A
Coolant hose - coolant housing 14056-JA01A
Coolant radiator cap 21430-8991A
Coolant radiator drain cock 21440-50Y00
Coolant radiator drain cock o-rings 21481-18000
Coolant reservoir 21711-ZN50A
Coolant reservoir bracket 21745-JA00A
Coolant reservoir cap 21712-ZN50A
Coolant thermostat 21200-6N210
Coolant thermostat cover bolts 081A8-8251A
Coolant thermostat o-ring 21049-ED00A
Coolant water control valve 21230-6N20A
Coolant water control valve o-ring 21049-6N220
Coolant water pump bolts 081A0-8251A
Coolant water pump housing bolts onto block 081A6-8001A
Coolant water pump housing bolts onto block 081A6-8301A
Coolant water pump housing o-ring seals 21049-3Z000
CVT oil pan gasket 31397-1XF0D
CVT oil pan bolts 31377-1XA00
CVT drain plug 31377-31X06
CVT drain plug washer 11026-JA00A
CVT cooling hose clamps 01558-00451
CVT cooling hose - inlet side 21632-JA000
CVT cooling hose - outlet side 21631-JA00A
CVT cooling hose pipe washers 21626-62U00
Drivebelt auto tensioner 11955-JA00C
Drivebelt auto tensioner bolts 081B8-8301A
ESLC shear-head bolts (electronic steering lock) 48703-06F0A
Exhaust manifold gasket 14036-JA00A
Exhaust manifold reat heat shield 16590-JA01C
Exhaust manifold reat heat shield bolts 14069-ZN50A
Exhaust manifold studs 14064-JG30A
Exhaust manifold studs nuts 14094-JG30A
Engine oil dipstick gauge with o-ring 11140-JA00A
Front axle lug nut 40262-2Y00A
Front exhaust pipe gasket 20691-19U0A
Front exhaust pipe front studs 14064-JG30B
Front exhaust pipe front studs nuts 01225-N0011
Front exhaust pipe rear studs (for rear cat) 20606-D4200
Front exhaust pipe front studs nuts 01223-N0011
Fuses 24319-89910/5/20
Gas cap with securing loop 17251-ZX60A
Motor mount top torque rod (dog bone) (pass's side) 11350-JA00A
Motor mount top torque rod bolts 11298-JA03D
Muffler hanger bolts 54459-0M10E
Oil cooler bolts 11035-JA01B
Oil cooler gasket 21304-JA01B
Oil cooler gasket 21304-JA00A
Oil filler cap 15255-9N00A
Oil pan bolts 11035-EA000
PCV valve 11810-6N202
PCV valve hoses 11823-JA00A
PCV valve hoses clamps 16439-42L0B
PCV valve o-rings 11812-6N200
Blow-by hoses 11826-JA00B
Blow-by hoses clamps 16439-V500A
Purge solenoid inlet hose 14912-JA00D
Purge solenoid inlet hose clamps 01558-00411
Purge solenoid outlet hose assy with clamps 14912-JA00A
Purge vapor service port (evap hose assy) 14939-EA200
Purge vapor service port input hose 14912-JA00E
Purge vapor service port input hose clamps 16439-42L0B
TPMS sensor 40700-JA01B
TPMS sensor caps 40703-JA00A
TPMS sensor lock nuts 40780-JA01B
TPMS sensor o-ring seals 40702-JA01A
Vapor canister air filter 14953-JA80A
Vapor canister drain hose 18791-ZN50A
Vapor canister output hose 14912-ZN50A
Vapor canister output hose clamps 16439-ZN50A
Vapor canister vapor hose 17335-JA00A
