Apprentice Technician
ok so with just changing motor mounts is there anything else that would be required major like changing transmissions, axles...that type of thing...and if so what engines can fit into this car.....
Searching is your best friend... The 2.0 will swap in with some work and replacement (since it was an option). This swap has been asked about so many times, there should be plenty of threads on it. Read and learn on.
the GA16DE is the top of the GA engine family. if you're going to do a swap, you need a full engine/tranny/mounts/axles/ecu/harness.
