LongIslandMax said:
1990 Maxima ; I just replced the fuel pump and i hear it workin but i can't get it to turn over. Where do i start to find the problem??one thing i noticed that the security light is blinking, would that prevent it from starting { it is cranking}. I am trying to fix it for a friend. any suggestions would be great!!
I agree about the fuel pressure regulator. The pump gets blamed a lot for no start conditions, but sometimes it turns out it was the regulator. Check fuel pressure, I'm not sure what psi your car runs on. If the security system was engaged, the car wouldn't crank. Don't spend your friends money needlessly, make sure you know what's wrong before fixing shit. I know I've spend money on a distributor I didn't need, but when your car isn't running you get desperate!
Edit: I thought of something else, an easy thing to check. Take the plugs out and squirt some oil in the cylinders, it may be flooded and not getting compression. Just a thought, and all you have to pay for is the oil (and every one of us probably has oil lying around somewhere).
