i recently bought a rb20det engine and shortly afterwards i bought the wireloom.
I would like to know the rest of parts that i will need to attach to the wireloom for it to work. The wireloom is complete, know cut off ends are there. They are all plug on ends.
i know about the
- pickup coil
- coil pack
- distributor
need to know the sensor names?
thanx for helping
-regulator connection(on alternater)
-constant + (also on alt)
-knock sensor (on the block, underneath the plenom)
-Crank angle sensor (in front of the cam timing cover)
-Injectors (if its not already on the loom)
-O2 sensor
-air flow meter
-Tps sensor (on throttle body)
-coolant temp sensor ( near where the outlet hose connects)
-AAC (attatched to plenom)
-air regulator (under neath plenom)
I might have missed a few things but this should keep you busy for a while.
Is this an auto or manual loom?
jnr_chin said:
i know about the
- pickup coil
- coil pack
- distributor
RB20DET's dont have a pick up coil, nor a distributor.
They use a Igniter (the wires from the igniter go to each individual coil.
The CAS runs off the exahust cam which replaces the old dizzy types.
RB20's use 6 individual coil packs not one :cheers:
Discussion Starter · #4 · (Edited)
Thanx a lot!!!!!
u surely helped me out i mixed up the distributor for the igniter.
I already got the sensor on the timing cover i just didnt rememmber the name or i think the person who told me the name said the wrong thing.
I also got the coils.
So i guess this is almost everything to get started basically? Its a manual loom.
BY any chance do u know if it is possible for me to use another fuse box other than the stock one. The engine is in another car.
