Sup Mod keeping the peace
A P1078 code can be caused by any of the following conditions:
● Harness or connectors (Exhaust valve timing control position sensor circuit is open or shorted)
● Exhaust valve timing control position sensor
● Crankshaft position sensor (POS)
● Camshaft position sensor (PHASE)
● Accumulation of debris to the signal pick-up portion of the camshaft
Check the ground connections for tightness and oxidation. You can get a PDF copy of the FSM from:
Nissan 350z Service Repair Manuals
