Just recently bought a 96 200sx se and two days ago, the belt connecting to the a/c and what not started squealing real bad. just replaced it and it stopped the squeal for the most part as long as the a/c isnt on. If I turn it on, the squeal comes back. Any suggestions?
I had that problem w/ my last vehicle (92 isuzu pup) -- replaced the belts (maybe a little tight) and was still squealing after about 2 weeks and checking (retightening or loosening as needed) it cleared right up.. and as a last resort you can always attempt a little belt dressing. but go lightly if you do b/c too much is not good for the belts...
Might also want to check and make sure of a couple other things, if one of the pullys is freezing up due to bearings wearing out or there's oil on them or the belt it will squeal but definately make sure it's not too tight or too loose though.
