Need help big time! ka24e
870 views 5 replies 3 participants last post by  rogoman
#1 ·
I have a 1990 240sx and i bought a rebuilt engine that i'm putting in it. It's the same ka24e engine but the block is completely different. The motor mounts wont even match up. I was wanting to know if i could just use my block and switch everything else from the rebuilt engine to my original block.
#6 ·
You should be able to use all the internals in your old motor. However if your old block is severely worn, then the cylinder walls will probably have to be honed or bored. In this case the pistons/rings from the rebuilt motor may not match up.
