1 - 9 of 9 Posts
2018 Nissan Pathfinder SL
Are you sure its coming from the front seal ?
Check the Oil pressure sender near the Oil filter.
My power steering hose is leaking and making a big mess at the front of the engine as well...
Check the dealer I think that is where I heard of people going for it. If i were you though before you go any further I would verify that this is indeed your issue. Just pull it apart again and inspect the crank snout and see if it's has any sharp edges or groves in it..
same thing with my car. after i replace the front seal all of the sudden my power steering hose is leaking! so i was like, wtf! how'd it happen? so, when i take a look its coming from the short rubber hose connected to the reservoir and replace a new one with the clamp..
My power steering pump started leaking after replacing also. Just had to tighten my clamp on the hose.
i found the leak.a screw from my lower chain tensioner was too long and i cracked the back of the screw housing from the inside.now my engine knocking under the valve cover by the timing chain after putting gas in it.i got 213,000 mi on it and put in 87 octane.does anybody know if it could be the gas?
Wow my PS pump started leaking after changing pulley and seal. Prob should replace the hoses soon anyways....
Have you checked the oil and timing?
1 - 9 of 9 Posts
