Just replaced my negitive battery cable. Soon after that it just does not want to turn over. My lights do not even work, also checked fuses. What sould I do?
You should check the battery and both cables. You should also look for corrosion on the other end of the cable on the block. If you have any questions, feel free to e-mail me at Ray Brandt Nissan Answer Guys
I had a huge problem with my starting my SE-R for a long time.
Changed a few starters and nothing...
Turns out my ignition switch is bad.
I just ran and external switch through a relay and never had a starting problem again.
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
