I have a Nissan Pulsar GTi-R with a SR20 DET engine which has knocked up and cannot find parts for.
I just managed to source a SR20 engine.
Can I use the cylinder head and the manifold from the DET engine and put it onto the SR20?
And yes I used to rally with the Nissan until the engine seized up ...
if the motor is from a de naturally aspirated you cant use it. it has a higher compression ratio. and the det block has a lower comp ratio. and there might be a difference with the piston oil squirters that shoot oil onto the bottom of the piston. im not sure if the de has those squirters.
