Yep, pulling the bulb will fix it. On the '02~06's, the wiring diagram shows the trunk lamp is on its own circuit. Nothing else will be affected.
Yep, pulling the bulb will fix it. On the '02~06's, the wiring diagram shows the trunk lamp is on its own circuit. Nothing else will be affected.I’m not sure if I take out the bulb if that will solve my problem or not but I don’t want to try it and be stranded some where if it doesn’t work! Please help!!
Thank you so much!!!Yep, pulling the bulb will fix it. On the '02~06's, the wiring diagram shows the trunk lamp is on its own circuit. Nothing else will be affected.
