Dame tu cola!
i was doin my oil change and i noticed a smell. so i smell around and noticed that the smell came from the oil !!! i dont think its suppost to smell like this, im starting to think that my piston is bad or could it be just the o-ring or something else? what do u think?
Making lots of short trips which don't allow your engine to get fully up to temp?
Maybe your PCV valve isn't working properly (blocked).
Maybe you have a leaky fuel injector(s) which is/are loading up one or more cylinders with fuel?
Dame tu cola!
MrEous said:
Just curious but how is your car running? Rough? Does it miss? Do you have a check engine light?
im not driving the car right now. i have an electrical problem plus i think the ignition timing is off or that could be the whole cause im not sure . the car right now wont even turn on. my check engine light is on.
