I recently bought a 95 240sx. It needed a clutch and water pump gasket. I wanted to rebuild it so i did. new bearings, pistons, timing set, everything. I put it all together and now the idler gear is turning but the distributor gear on the end does not. i loosen the bolt and everything turns. what is the torque on the bolt? do i need to take the front apart again and replace the gear? i am at a complete loss!
