Hello All-
I own a 1996 Nissan Maxima with +/- 154,000 miles on it.
Over the past year I've begun to notice that,at speeds in excess of 70 MPH or so,a vibration begins to occur in the front end and I feel it through the steering wheel. Once I slow down,this all disappears. Three shops have told me it's not the front end alignment. Any thoughts?
Thanks
THINK BLUE
Hi there, welcome to NF. I would suggest you run a search for your problem. Off the top of my head it sounds like something that would be fairly common. If that doesn't turn up any anwsers, then you should make a thread about it in the appropriate section. You'll get a lot more looks and responses. Good luck :thumbup:
The Right One Baby!
Welcome to NF! Sounds like you need a hi-speed alignment. I will also move this into the correct maxima section for you but i'm sure that all you need is a hi-speed alignment.
In Ur Threadz - Deleting!
mtkisco said:
Hello All-
Thanks
It could be an alignment problem, tires, rims, or suspension problems.
How old are your tires? Are they worn down?
