I have a 91 se-r and i changed the starter changed the battery, the altenator is good. Every time i turn the ignition i hear the starter tick, once for every turn of the ignition. after turning the ignition a couple of times it finally kicks on......i have no idea whats going on....... someone please help!!!!
check possible corrosion on the terminals and the connections. every time my car won't start that's the problem.
I'd go with the battery terminals too. Nissan's love to corrode I hear. Also, this should've been common sense when it was replaced, but did you replace the solenoid on the starter too? If not, that would definitely cause the problem. Although to my knowledge they're sold together, you never know... another problem may be a bad connection on the negative battery terminal (the other end that bolts on to the starter mounting bolt)...
