Well, im about to get back into the modding scene around the summer or the fall once i have ample fundage. what i as wondering is if anyone knew if id need to get new axles if i swapped the sr20 motor into a qg powered sentra... and would i have to get motor mounts that are exclusive to the b15 chasis or would the motor mounts from the older sr20 work?
Powered By hopes & dreams
If you get the b15 SE tranny, get the axles with it. They might be slightly different than the xe/gxe, however I'm not sure.
call a nissan dealer and see if the part numbers are the same. You'll need the b15 mounts and probably the b15 SR crossmember.
