my idea is to reduce the resistance of the wires and connections between the coil and the batery. So the coil can accumulate more energy and the result of this is a stronger spark and this results in a more stable igniton -> more power?
I lend my car to my brother so I can't do any measurmet at the moment.
What do you think of this idea?
ex-Super *********
Does your P10 have a GA(I dont know too much about P's) If it does and you have no N2O or boost..Leave the stock ignition system alone and save your time and money for other parts. I imagine even stock SR sytems are the same way.
Is the Primera not the Mexican Infinity G20? I thought I heard someone say that. If so, it has an SR20 in it.
my p10 has a ga16.
The G20 is a USA primera!! ans yes the G20 is only powered by a sr20!
Do you realy think that there is no need for it?
ex-Super *********
If it is a GA then with out boost or N2O there is no reason to upgrade the stock ignition system. The stock system is so good that it will fire through a small amount of boost or N20, with that said you can see that it is plenty capable of any NA GA. For more info about this go to www.sentra.net and look at Mike K's engine article.
