I have a 2004 Nissan Sentra SE-R Spec V w/ 6speed Looking to change tran oil but no fill plug, found somewhere i have to remove the speedometer drive pinion not sure which one that is. Anyone have a pic or description
Thanks,
Rich
Thanks,
Rich
There's a fill and drain plug accessed from the driver's side wheel well (10mm allen bolts)
-Remove fill bolt
-Remove drain bolt
-Re-install drain bolt
-Fill w/ tranny fluid
--either w/ exactly 2 3/8qts or fill it till the fluid reaches the fill hole
--it's easiest if you have some sort of tubing and/or funnel to fill the transmission
-Re-install fill bolt
I use BG Synchroshift II. I got mine from my local NAPA store
Also, availble here --> https://secure.buschurracing.com/ca...d=825&osCsid=7f9685536f674d048185a5c829b93b6d
btw, I know it says "use only in evolution's transmission"
It is perfectly fine to use in the Spec Vs transmission
