1 - 7 of 7 Posts
· Constantly Bored
heh, those of you that know me, know that my car is a piece of crap.
here is the new "somethings wrong with mclaren's car" thread:
out of the blue monday, my car got really hard to shift into any gear above second. the only smooth shifting now is: anything to neutral, 1st to 2nd, and reverse. 2nd to 3rd sucks and 3rd to 4th sucks and 3rd to 2nd sucks
i thought maybe my synchros were going, so i tried to revmatch. sometimes it works, most of the time it doesnt. sometimes when i try to go from 2nd to 3rd, i try to push it into 3rd and nothing, when i let up off the clutch it grinds. i have to put it into neutral, drop the clutch. push the pedal again and try to put it back into 3rd and it works sometimes. sometimes if i speed shift into 3rd and 4th, sometimes it goes right in.
sometimes i have to try to previous method AND revmatch on top of that. its getting really annoying.
i was doing some reading, and it led me to believe that some bushings are bad, or my shifting fork is bent.
i dont think my clutch is bad. no slipping or nothing and it catches fine.
i dunno whats wrong with my p.o.s. car, and im getting tired of it. my car will be paid of next month, so i could get a new car. but i dont want monthly payments for another 4 or 5 years, so thats out of the question.
thanks for all the help you guys can give me...
· absolutely classic
I would check the transmission fluid level. If the fork was bent I would think it would be a constant problem. The synchros in these cars are pretty weak, so that could be the problem. I would just change out the tranny fluid to something like Motul or Redline. Make sure any fluid you get is rated GL-4. Go onto www.sentra.net, there's lotsa great information there about recommended fluids.
Out of curiosity, how do most guys fix the weak synchro problem? I've heard of cryo-treatment, but I don't believe there is anyone around me that does that. I would like to do some road racing/ autocross with my car. Thanks.
· Constantly Bored
could bad motor/transmission mounts also cause this problem? i now get a weird vibration when i reverse and when i step on it a little in third gear theres a loud thunk and some wheel hop, as if the whole engine is moving...
· im2kwik4u
that could be the problem, because if one of your motor mounts is damaged, the motor is not leveled anymore, it can sometimes be shifted to the side, causing u to have problems when going into gear. If u get motor mounts get the OEM if not your car will be rattling all over with the Autozone/discount autoparts one
· Constantly Bored
this just in...something in my tranny blew and now its stuck in second gear. the stick is in neutral, but its stuck in second gear...
new plan now...if i can actually do it, is to drive to another state and buy an se-r
im sick of this pos...
1 - 7 of 7 Posts
