Just the other day on the way to work I noticed that I was beginning to loose 1st gear. It felt kinda grittty. Shortly there after I noticed that 2nd was going out too. It did it all the way up to 4th gear. What is even stranger, is the fact that when the engine is cold it goes into all gears with NO problem.
Only after about 30 minutes of stop and go movement, the transmission starts to act up. Another odd fact is that it always does it about the same time. Like the gear oil is heating up too much. Oddly the gear oil was changed about a month ago( When clutch was put in).Here is the order in which I loose gears:
#1> Reverse is always the first to go out
#2> 1st is second to go out
#3> 2nd is third to go out
#4> 3rd and so on
Tried searching but it turned up no useful result. Any help would be appreciated.
#4> 3rd and so on
