Hello everyone,
I have a Nissan Maxima 96, and it has been working fine until yesterday. I came home from work and the brake lights were still on even the engine was off, the key was removed and everything was turned off (light switch...). The only way I can turn them off is to remove the brake fuse. I have to put brake fuse back when I go to work, and I remove the fuse when I am at work or else the battery will run out. Does anyone know the solution to this problem? Thanks alot for the help.
