I think i'm having a problem with my lug nuts for some reason they keep on coming loose. Has anyone experienced this before.
About a week ago i was hearing this thud thud thud noise thought it was just a tire with not enough air in it so i checked all my tires filled them and figured i would be fine. Well the noise didn't go away so the next day i decided i was going to rotate my tires and figure out what the problem was. As i was loosing all the lug nuts i came to the front drivers side tire and 3 lug nuts were already hand loose. i didn't even need the tire iron. on the 4th lug i ended up breaking the stud because it was all fucked up. on the back passenger side one lug nut was hand loose. So i rotate my tires and get the stud fixed. today i go to check my tire pressure because i think i have a slow leak in one of my tires and i decide to check the lugs. Yeah 2 the on the front tire were loose again and one on the back tire was loose. I know i tighten all of the lugs and the front tire was tighted at a shop so there no way it should be loose.
I'm just wondering if theres a reason this is happening and if anyone went through it before and how they fixed it.
thanks
thanks
