With the ignition off I have 0.66 volts at the radio (red wire) and cigarette lighter, engine off. Engine on is 0.88 volts. The 7.5 amp accessory fuse, 10 amp mirror fuse and 15 amp audio fuse under the hood are all good. The yellow “keep alive” wire to the radio is dead. Battery shows 11.88 volts off, 13.50 volts running.
This whole mess started when I found the radio on (aftermarket radio) as I was walking by the truck. Several times the battery was dead after we suspected the radio somehow turned on after shutdown. The radio is supposed to turn on when the engine is started and turn off at shutdown. I had 12 vdc at both the red power wire and yellow keep alive wire earlier this am.
2003 Nissan crew cab with power door locks
thanks,
len
thanks,
len
