hi, i have 2006 nissan xtrail. The problem is that my car won't ever reach 2000 rpm. When i force to push pedal to get higher than 2000 rpm then the rpm will immediately drop to 10-1000 rpm and hunting and then back to normal idle. I used scantool to check sensors data.
MAF : 1.2 v - 1.58 v , cannot get higher than 1.58
o2 sensor : always 0.01-0.03V
sometime i got System too lean bank 1.
What's symptom of bad maf and o2 sensor?
Please i need helps, they replaced my fuel pump with new one and also cleaning the fuel filter but problem still exists.
Thanks...
They have replaced your fuel pump and fuel filter but what has been done to the injectors ?
