good day sirs'.. i have a ga16de with cold air setup and now i want to add cams to it but can't find one for this type of engine.. i tried at jim wolfe but no cams are available.. by the way my location is in the Philippines.. any help would be appreciated.. thank you very much..
Your only option if you can't find used JWT cams is to get regrinds.
What is a regrind? Here is an informative ga16de regrind post:
GA16DE rally car article with engine build info
Someone in this thread found a good deal, $150 each at deltacam.com:
Regrind Cams (GB)
You would also need to get either new bigger shims, or double up on them in order for the regrinds to work. I think nissan charges $9 a shim and you need 16 of them. You can learn how to do it in the Haynes manual: end of chapter 1, Valve clearance and adjustment. That information is also in the field service manual which you can download here: Nissan Sentra Factory Service Manuals (FSM) Just download the 1994 sentra one, go to EM, and click the Valve Clearance button under GA.
