NF Mod/Nissan Master Tech
The load sensing valve is by the rear axle. It's a proportioning valve that adjust the rear brake fluid pressure based on the difference in height between the axle and the bed of the truck, which will vary depending on the weight of the load in the bed. It "could" be bypassed, but it will affect the brake performance when the bed is weighted down. If you drive around with a light load or empty most of the time, you probably won't notice the difference. I'm showing a part number of 46400-32G00 with "limited availability," which often means if it's not sitting on the shelf at someone's dealer, it's not available. It's also not cheap with online prices around $320 and an MSRP over $400, but cost is irrelevant if you can't find the part! Salvage yards might be the only option if you can find one that's not all rusted apart.
All it does is help the brakes compensate for a loaded bed. For years, trucks never had a load sensing valve and they were fine and yours will be fine if you bypass it. It's a nice feature to have, but if you can't find a new or rebuilt replacement, it limits your options to either bypassing it or finding one in a junkyard.
