so on wednesday i put in my new foglamp bulbs, and now my little warning light in my digidash is saying my rear lights are blown, and they aren't, any ideas on how to fix this?
No, when you installed your fog lights. Something happened when you replaced those. Maybe knocked something loose or caused a ground fault.SanMarcosZfreak said:all i did was replace a burnt out bulb with the correct size and voltage replacement
I suppose. However, when you've been working on cars as long as I have, you began to realize there's no such thing as a coincidence......SanMarcosZfreak said:no i cleaned all the connectors, i actaully reconnected a disconnected ground wire. i think its something completly seperate, i think its jsut a concidence
SanMarcosZfreak said:i found out what the problem is, i installed LED bulbs and the sensor doesnt like them, so i jacked some 1157's from a 240sx we ahve at class that we use for parts, any idea on how to make the sensor liek them, or could i use the silverstar 1157's
SanMarcosZfreak said:hence why im bypassing teh sensor
