1 - 8 of 8 Posts
I have an 02 Sentra XE automatic. The light on the gear shitf(P,N,D,1,2) went out. I have looked for a fuse but cannot find one or am looking in the wrong area. Anyone know what causes this and can it be fixed?
TIA
Mike
This happened to mine. I just went to autozone with the light bulb and just bought one that fits. There seems to be no part number for this particular bulb.
these are regular 12 volt automotive socketless bulb
#1194 don't buy the cheapest cause it's a bit of a twist to replace,
the socket is clip by under you have to twist it half a turn then pull down on it and the wire is pretty short and goes around to the other side of the shifter but can be loosened a bit, so use patience.
B.
1 - 8 of 8 Posts
