1 - 13 of 13 Posts
I have a slight knocking noise coming from the nearside rear of my 2005 T-Spec (68k miles). The knocking is most noticable at very low speeds, entering/exiting the drive etc. I've had a look and feel about under the vehicle, the only movement i can detect is that at the anti roll bar clamp to the chassis.
Has anyone experienced this problem? If it is a simple bush replacement, it looks like it could be done DIY, any thoughts guys?
Thanks for getting back to me man.
Tried the strut top bolts, definately not that, they're all tight. Any other ideas? Our roads in Scotland aren't great, plenty potholes, do you think rubber bushes could be worn?
Nice website!
Fatman:)
strut oil leak
I've now noticed that the suspension strut has an oily film on it. I'm now thinking that the knocking noise (now more of a rumble) is down to the loss of oil from the shocker, presumably through the top seal. I notice also that the rubber gaitor at the top of the strut is badly perished. Both rear rubbers are the same.
Looks like i'll need to have the shocker replaced.
Cheers,
Fatman
Just adding my pennies worth to this post, if the sound is more like a flexing noise - basically the type of noise if you had a large piece of board and flexed it back and to it will be the anti roll bar link arms, I changed my OSR at 30,000miles and I am changing my NSR tomorrow as is happens at 68,600 miles I noticed it was worn and loose when underneath the car [in a pit at local garage] whilst having my brakes checked - I sneaked under and checked it out as I am hearing the same noise as before £28 for the new part - have arranged with garage to use their hydraulic lift making things a little easier. My local nissan dealership spent one hour looking at the car the first time and never found the fault - I try to stay away from the dealership now as they only want MOTs etc or mobility servicing they are so lame.
I fitted the new anti roll bar link arm, I purchased a after market version bought from Welcome to Blue Print - Japanese Car Parts, Korean Car Parts & American Car Parts - The Parts for Japanese, Korean & American Cars [check out the website] part number ADN18530 on their paperwork it is listed as a stabilizer link for £7.00 yes £7.00. it does not matter which side of the vehicle it is fitted to they are inter changable. Nissan wanted £28.00 your havin a laugh. it took 1/2 hr to fit ended up not using the hydraulic ramp as it was too time comsuming, easier to jack the rear up, take the back wheel off and loosen the bolts 14mm and refit new one - bish bash bosh - job done - happy days
X-Trail Moderator
If you have a picture, could you post it for us to see...
It would be much appreciated.
thanks,
Sorry do not have the pictures or the x-trail anymore as far as a offroad vehicle it was certainly off the road more than it was on, the problem that made me jump ship from the x-trail that i had for 5yrs was after having the car recalled to have the fuel neck filler replaced and whether or not debris had fallen inside the fuel tank i don't know but the car never ran the same afterwards, and i put up with it changing the fuel filter pot, after one garage bypassed the filter and said the car run fine until it was re-connected removing the fuel tank twice and having 6 fuel filters and a new mass air flow sensor in 18 months i decided enough was enough so it went with only 85,000 mls on the clock
1 - 13 of 13 Posts
