I have a 98 200sx se-r. I had a check engine light pop up: Knock sensor malfunction. So I lifted the car up to check it out. I found out the wire was damage. I see that the wire is wrapped with a metal wire. How do I repair this kind of wire? or do I just replace the whole harness?
2018 Nissan Pathfinder SL
Are you saying the wire has a ground shield?
I assume this is just a one conductor shield wire. Measure the core dia, strands etc.
you can get a similar wire and solder a piece in, it would be easier off the car.
Then heat shrink the core and then repair the shielding.
Anyway i think the knock sensor would come with a new wire to the connector.
Edit:... looks like you don't get a pigtail, sorry you will have to repair it
