1 - 8 of 8 Posts
Yeah if you don't push that little button behind the key you're not gonna get it out...push the button turn the key back at the same time, and then pull it out...
Tarmac Terrorist
pm1kmm said:
Gently tap the key with a mallet. Later when the key is out, spray some WD40 on the ignition keyhole. Hope this help. Is ur car park on a slope???
Is the key stuck in a position? Can you start the car with the Key stuck?
Also the Safety key lock thing might be worn out, has the key given you trouble previously?
1 - 8 of 8 Posts
