1 - 10 of 10 Posts
I think I lost my mod-nes
Hey,
My chimer for leaving my key in ignition or headlights on, etc. quit working recently. I don't know how to get it working again. I assume it's a fuse, but I can't find a fuse labeled hadlight chime. If anyone could give me some pointers, I'd appreciate it. Everything else still works fine on the car, and the dealer wants $60 to even tell me what's wrong with the car. I can live without a chimer before I pay that, you know?
Thanks.
Former SuperMod
I yanked out my fuse that enables part of the "door ajar" chime... meaning, it still chimes 4 times when I start my car, but it does not chime when my car is running and the door is open. I hate that stupid thing! :) I'm trying to remember the exact fuse.... try the one labeled "Electronics (B)"; it's a 10amp fuse.
BTW this is on a B13 '94 XE.
Also check your door sensor/switch. That's what happened to mine. I took out the door sensor, took it appart and found that the metal contacts were not sticking properly. That fixed teh chime for both the key in ignition and the lights on. Hope this helps.
Ok, not to make it a known fact that I'm kind of clueless, but how do you take out the door switch? Is it that little rubber looking thing on the drivers door that gets pressed in when the door is closed? Could this still be the problem, even though my interior light works like its supposed to when the door is open, or are they two separate electrical contacts involved here?
Yay, thanks Brainstorm. I did what you suggested, and it's working perfectly again. I have to admit that now that it's back, it was kinda nice to not have to listen to that ahiming for a few weeks, but I'm still glad it's fixed again.
Head light and key in ignition chime
I had the same problem with my Nissan sentra. I decided to try everything on this page. I checked and cleaned all the fuses and did what brainstorm suggested and whala! everything was back to normal.
Thanks y'all
:hal: soo excited
What's "whala"?
1 - 10 of 10 Posts
