Valve adjustment is hydralic on the KA24, unlike the Z24.
Thanks so much for the advice,When i did the in car overhaul of the 1988 Z24, i had this problem. Al lthat work and it just cranked but wouldnt start! But i thought for a bit...got my tools, removed the distributor and rotated it 180 degrees. Next turn of the key she started right up - i had put the distributor in 180 degrees off! (Always make punch marks when removing the dist).
Some other things that could be wrong:
1. You forgot to connect an important wire or component
2. Spark plug wires installed wrong and not in proper firing sequence
3. You forgot to reattach the ground cable to the frame (i cant remember where it is)
4. One or more valves too loose or too tight. You did check the valve adjustment didnt you? You may want to add .002 to the factory settings when picking your feeler gauges for this chore, since the engine will be cold and the settings are usually designed for a hot engine.
You will have to rotate the crank with a breaker bar and socket on the crank pulley (DO NOT turn backwards turn it clockwise only, facing the engine! I bent valves turning it backward once!)
There are many complicated instructions you will find to adjust the valve clearance and but just remember this: All you have to really do is to adjust the clearance of that particular valve, when the camshaft is on the base circle! (rocker arm not touching cam at all and free to move, not under camshaft pressure).
5. do a compression check. Maybe the valve job got botched by the machinist. If so, you need to know this.
6. Some other things that could cause this condition: worn out ignition switch (sounds weird but this actually happened to me - new engine, started intermittenly, it turned out to be the switch.) - worn out cap and rotor, broken distributor shaft (rotor should NOT turn freely when engine is off, if it does the shaft is broken - again, this happened to me too).
Does it do it just at startup? or when you're running? If it's just at startup, you should try the factory oil filters. they hold pressure better over time. If it's when running, you may have an aging oil pump, which is a lot easier to replace than a tensioner. see if you can get your oil pressure checked.Great Writeup!
I've got a 97 2wd that I changed out the chain, tensioner, & sprockets a few years ago around 150K and after that all rattle was gone. It already had the metal guides in it and all I could find is the chain was very loose. I swapped everything anyway and this year the rattle gradually came back around 185K and now is as bad as its ever been at 187K. I think its related to the tensioner because I can take the valve cover off and reach into the front cover and push the tensioner to the left forcing the oil out of it and then start it up and (after the horrendous noise caused from forcing the oil out clears up) it will be quiet for about 3 months and then come back again? Strange. The chain is also getting pretty loose again. A fella I know who worked for Nissan in the past told me he thought it probably had some trash in the oil gallery leading to the tensioner restricting/blocking oil flow to the tensioner and that he always blew it out with compressed air when he did the timing guide change.(the oil hole behind the tensioner going into the motor block). I didn't know about that trick when I took it apart though. Also it would still seem like the spring in the tensioner should still take up the slack at startup. Maybe I just got a faulty tensioner. I'll probably pull it back apart later this year. I also wanted to say those of you with the 2wd. You don't have to take the oil pan off to swap chain/tensioner. I think I took the front 3 or 4 bolts out on each side and loosened that many more and it will let the pan give enough that you can get the front cover off and on ok. Yeah the little Nissan has saved me a ton of money in the past and I'll just have to fix it....again!
Good Luck,
Brian
Where did you get your parts? I'm about to dive into this project.I just finished this project!:
