it's always something...but still, helluva truck.
my fan clutch is stuck in the engaged position - the fan runs from the moment the truck is started up in the morning, until the end of the drive, as far as I can tell. and it makes the truck sound like a school bus when accelerating.
is the fan clutch part of the water pump on my truck, or can I just buy a fan clutch and install it without having to worry about new gaskets or draining the coolant?
what's the quickest way to go about this...it looks like if I remove the fan shroud and the plastic undercarriage shield I should be able to remove the fan and possibly the clutch. is this right?
thanks for any advice you've got on this job.
