Per a previous post, I replace the head on my recently obtained 1995 Altima GXE w/ the 2.4 liter dual over head cams.
1st problem - I pulled the head with out marking anything
2nd problem - I bought a head and cam set from a salvage yard and they didn't mark anything either.
So - when I put the car back together, I used the online manual that I was graciously point to from this sight.
I had #1 piston up, placed on head gasket, put on head, torqued per instructions, placed cam closest to the front of the car (I placed w/ dot at 1 o'clock) then the cam closest to the firewall (I place it in the 11:00 o'clock).
This is what I thought I interpreted via the manual and other online info.
I'm thinking that both cams should be at the 1 o'clock.
The car will start but will not idle, at 3000 rpm rev up the car sounds like it normally would but I even has pressure pushing out the air box.
Can any one give me advise? I can't be far off and am wanting to complete.
Thanks -
Discussion Starter · #2 ·
Going Crazy -- need some Love
I have pulled the cams and attempted to readjust my timing about 6 times now...
You has the LOVE??
I need some serious direction.
As mention in my other post -
I replaced the head and gaskets --
1st start attempt fired while holding gas -- sounded good at 3 thou RPM.
I've readjusted about 5 more times and all just turn with no real attempt to kick over. I do notice that the 1st turn each time I get a little back fire.
Help......
