Like two months ago i got my 2001 pathfinder se 5 spd 4wd. Then the first month, boom, the first o2 sensor (bank1 sensor2) gone. Ok, no big deal, it could happen to any car. I decide to do a tune up because of the mileage (145K kilometers) found out that the previous owner never did anything to her.
Now (last week) it was the second time the the check engine light came on with the codes for both rear o2 sensor lean...b/c i work on Subaru dealership i have tools and some books, but nothing for nissan, and the technicians at nissan don't like to talk, so thats another problem (one of them told me theres a bulletin for ECM reprograming for O2 parameters, True?)... so i need your help with a couple of things:
1. Whats the pressure for the fuel pump before the filter on idle and under accel
2. under medium accel when tach reaches 4000 rpm engine holds for a bit and then keep going till redline, but on hard accel, no problem, all good all the way
3. Sunroof doesn't open or close with the one touch function on the switch, only works little by little. Maybe the switch.
Thanks
Thanks
