Guys,
My 07 Pathfinder air bag light started flashing today. I reset it and it started flashhing again. Is there any way to diagnose what the issue may be?
Thanks
The most common issue on older Pathies is the spiral cable (clockspring), but that isn't a given. You should get the codes read with an airbag-capable scanner. If it shows any codes ("past" or "current") for driver airbag #1 or #2, then the spiral is causing the issue.
