1 - 8 of 8 Posts
Hello All,
I consider myself capable when it comes to auto mechanics but have come across an issue that has completely stumped me. I have a 2003 Nissan Frontier V6 (non-supercharged) (136k miles) that has bizarre starting issues. The symptoms involve random occurrences where I will only get a solenoid click but no actual ignition. If I keep turning the key to the start position it will randomly start. It may be two clicks or twenty. Below is a list of diagnostic and parts changed/tested:
1. Started out thinking it was the starter. Replaced the original starter with a starter from the Nissan Dealer. The issue corrected itself for about a week then reappeared.
2. I jumpered the clutch position switch and it started immediately. I went to the Nissan dealership and got a new switch which fixed the problem for a couple of days. Swapping the old clutch position switch back in made no difference. Sometimes it would start, sometimes not.
3. I tested the resistance on the ignition relay and it was okay but jumpered it anyway (Position 3 & 5 I believe) and it started just fine. I bought a new ignition relay from the dealership but after a couple of days the issue came back.
4. I tested the battery (which was only 1 year old). It tested fine but to be sure I tried to start the truck with a backup battery car start. Truck wouldn’t start on normal battery or with backup.
5. I pulled apart the dash and column to get to the ignition wiring running from the key ignition to the main wiring. It was challenging to tell but it appeared as though I wasn’t getting conductivity in the correct wiring when turning the ignition to start. At this point I replaced the ignition wiring with a dealer replacement. Didn’t fix the issue. Still intermittent starting.
6. I then checked the positive battery cable going directly from the battery to the starter (which also included another wire with two female ends, one going to the main relay box). I was getting around 13 volts on start if I remember correctly. I replaced this cable with one from the dealer ($150) and Hooray the problem disappeared for 6+ months.
Now after the 6 months the same symptoms are back. The only things that I can think of that it could be is the ground wire (which I thoroughly cleaned), a possible short somewhere (shoot me now), or a bad key ignition switch. My question is why did the symptoms disappear for 6 months.
Please help. I love this truck and don’t want to get rid of it but need a reliable vehicle. Thank you for taking the time to read this long post.
WOW!!! Over TWO THOUSAND views and ZERO replies! That seriously bums me out because I joined this forum looking for a solution to the exact same issue only my Frontier is a 98 with the four cylinder. I've also done pretty much everything you've done trying to solve it on my own to no avail, and my issue has gone from intermittent to won't start at all. I can still get it rolling and pop the clutch and she runs like the little raped ape she's always been, just once you turn the key off, she won't start with key the next time.
I know it's been awhile since you created this post, and probably won't see my reply, but if you do...did you ever solve the problem? What was it? I've got my fingers crossed that you check back here from time to time.
Thanks,
IronPig
It seems like I've read about quite a few negative battery cables going bad but internally, so it's not obvious by looking at it. Clipping a jumper cable from the battery negative post to the engine lifting point would rule out a bad cable.
Otherwise a DVM and a helper to turn the key while you're measuring voltages should pinpoint the problem.
2018 Nissan Pathfinder SL
Well my 2003 Pathfinder has just started to do this.
I suspected the gear selector switch, because if I moved from park to D and back it would start.
that is till yesterday.
Then it didn't work. I moved key back and forth and it started.
today I had to bang the steering column cowling.
So I suspect the switch.
It doesn't do this enough to trouble shoot, but I don't know why I never suspected the solenoid or starter.
BTW, There aren't many Pathfinders out there, for rare problem I look on Max or frontier forums, so I am puzzled as to why no replies.
Update.
I cleaned the battery terminals and applied red anti corrosion stuff.
Removed cowling from steering column.
Removed wiring from switch, all nice and clean. Replaced.
Inserted multimeter probe into black / yellow conector slot. Set up meter on instrument cluster.
Ok. So far so good.
Started about 10 times over a few hours. No problems. Meter spikes to about 11 v, very fast.
Went shopping no issues.
So I am stuck, no failures to diagnose.
Ordered new switch from Amazon.
Incidentally seems to start stronger, faster or is that my imagination?
Hope you got it going good again.
In the Future, You don't have to buy anything special to prevent battery terminal corrosion. Just use any General Purpose Grease all over the exposed metal on the Terminal's. I've been useing General Purpose Grease at least since 1988, and it's the cheapest and best method that I know of. Drove '93 Hardbody for 20 year's with no terminal corrosion. Got a Rideing Lawnmower that's 29 year's old and never had terminal corrosion; Lost count on # of Batterie's,, but never any corrosion.
Good Luck
Another Update.
Installed the new ignition switch assembly. No issues.
No failures to diagnose when meter was attached, so only assume my taking wiring plug off and re-installing, and wedging in multi-meter probe moved something in switch.
Will update if another failure
1 - 8 of 8 Posts
