Almost none of the lights work also the fuel gauge and the temp gauge do not work I need help fixing it
Check the fuses first; if they're OK, then the ground connectors may be loose or have oxidation on them.Almost none of the lights work also the fuel gauge and the temp gauge do not work I need help fixing it
Ok will doCheck the fuses first; if they're OK, then the ground connectors may be loose or have oxidation on them.
