I Installed the XYZ Racing intake off ebay, set me back $45 shipped, and $7 getting the bolts and a fitting that the kit left out... Now I have a check engine light on but the car runs fine. The kit had no place to insert the Air Temp that I unbolted from the air box, so I slipped it into the cone filter on the outside. I checked for leaks in the system but nothing seemed evident, and until my buddy gets back to school, I can't go in and get free use of the School Auto Shop's Computer Diagnostics System.
Has any one installed this kit on a 1995 GXE automatic before?
Is it the Air Temp that is the problem?
The car runs fine, but I have to drive about 80 miles to work and back each day so I have to know it works. I can feel and here the better power and sound in the top end, and it getting off the line a hell of a lot better. I can't weight to see the boost to my MPG on the freeway, most my work driving is done on I-5 from Albany to Salem (Oregon) and I get about 35 now doing 80mph thats around 3000rpm unless I can draft a pickup or something, that's taken it down as low as 2700rpm and man was it smoother in the air pocket.
who needs clearcoat
Under the ga16 section of the forums there is a post that teaches you how to check CELs. You don't need a computer, it's pretty simple. You pretty much just need a screwdriver.
thank you.
