i found this thread and it seems to be the answer to my problem.
my car has 80ishk
blownb310 posted this.
You guys are all missing a simple item that is more than likely the entire problem. I have seen this several times on a GA16DE. Under the valve cover there is a small rectangular seal that separates the oil being splashed around from the valvetrain, from the internal breather passage. This seal does not come with a valve cover gasket set. It must be gotten seperately. The Nissan part# is: 13271-51J60. You won't belive how cheaply and quickly you just solved your problem.
Please let us all know if I was right.
Thanks
i think this might be my problem cause my car started to burn oil shortly after i replaced the valve cover. does anyone have pictures of where this is? or what it looks like?
any help is GREATLY appreicated.
jj
Discussion Starter · #2 ·
my car has 80ishk
Thanks
jj
heres the thread link http://www.nissanforums.com/showthread.php?t=21229&highlight=spark+plug+torque
I'll snap a pic tonight and post it. I replaced my valve cover and that seal, and it fixed my oil burning problem.
As promised pics:
It is hard to see it in this picture, but is in the bottom center of the cover in the picture. It is where the cover has a dip down.
Here is the seal removed.
