Thanks, I did exactly as you said. the bolts were easy to get out.
I'd like to thank ZaneGrey who said I should check the ignition switch in the first place. After installing a new starter, new positive cable, relay and taking out the alarm I was still having the problem. I finally check the ignition switch and found the connection plate on the back was loose. Duct taped it and things were better. Found an ignition switch on E bay for $75 and put it in. Everything seems good.
Whoops to all who helped.
