· Admin and Sup Mod keeping the peace
To remove the ignition switch, you'll first need to remove the steering wheel. The combination switch then needs to be removed. Unplug the ignition switch harness connector. There should be two shear bolts that hold the ignition switch; remove these. That should do it.
