1 - 12 of 12 Posts
Anyone out there have any good suggestions?
I just bought a 1994 Sentra 1.6 Litre. It Ran great for the first fews weeks then just a few days ago it died in traffic. I got it home and replaced plugs, rotor, cap. What is does is follows: If I start it up and keep the rpm up around 2000 or so, it will continue to run. If I let it idle it will decrease its idle to the point where i can not bring it back to life with the excelerator and it dies. Almost acts as if it is slowly running out of gas. Any ideas?
Nissan Fanatic since 1999
I think i might have had this problem before, i cant remember what they did but they replace a couple of things. It might have to do with the Air Intake section. Also change the idle timing.
i think it sounds like the throttle body positioning sensor. i dont think they are cheap so i would consult before i bought. just a suggestion.
3 bar MAP
make sure ur there arent any vacuum leaks along the intake tract. a leak in a MAF car will make it run like crap. check hoses for cracks, lose connections, etc.
check the AAC valve for carbon deposits and the Air induction valve hose under the plenum, it attaches to the back of the plastic intake pipe, its about 2/4 thick. Check to see if that is cracked or off the intake pipe, the car will die if not connected.
The TPS is not the problem, the MAF may be the issue, check the harness for corrosion and use some di-electric grease on the contacts, also check the plug wires for broken sections.
Chris 92 classic
the only reason i say TPS is because my 98 explorer was doin the same thing. i took it to the mechanic and that was the problem. keep us up to date. im curious.
maybe you can have your MAFS regrounded, ive done it and doesnt encounter that problem again
Sentra Specialist
Bingo! Parvo's advice looks to be the most likely! ;)
I have to agree with sunnysentra's sugestion. I had the same symptoms that you described and they were fixed by cleaning out the aac valve with some throttle body cleaner. It took only a couple of minutes to do and cost about 3 bux for the can of cleaner. definelty worth a try
-dave
Sentra Specialist
Terry,
Have you diagnosed it yet? Are you going to troubleshoot it yourself, or will you have a technician look at it? I'm sure we'd all like to learn from this.
Thanks
To Terry
I am now having the same problem with my car.
Did u manage to sort the problem out? I hope so since it has been several years now:)
Please let me know what you did to get rid of the prob. Thank you
I have sent my car to the Nissan technician 3 times now and paid lots but still not having the matter fixed:(. WIsh I discover this website sooner.
I will also try all the different suggestions given by the others.TQ
1 - 12 of 12 Posts
