question for you guys..i've got a 90 Sentra (GA16i) that is just kicking my ass.
the heater got lukewarm and the idle went up really high right before xmas. i was told by a shop that professionally flushed the cooling system, that they thought it had blown a head gasket. after i got back in town from xmas, got to scratching my head and decided to fiddle with it myself. so far i have replaced TWO thermostats, replaced all the cooling hoses and heater hoses *almost all originial hoses and nasty rust/corrosion*, put K&W Block Sealer *just in case there was a problemw with the head gasket*, back flushed the system so there is no more rust/corrosion but yet its still acting weird.
the idle is really high like its starting cold constantly, although i can hear for a few seconds when the thermostat opens, the idle drops and then back up to a high idle again. the gauge will go about halfway up, sometimes a bit more before it will go down again. we're a military family and we live on the base where the speed limit is 25 and lots of stop signs. i just replaced the coolant fan switch last week..the radiator fan DOES come on but not until the coolant has gotten so hot that it goes into the overflow bubbling. then i checked out the ECU and it popped up with 2 codes...23 and 25, idle switch and AAC valve respectively, which would explain the high idle. everyonce in awhile i can switch the heat on, and feel a blast of hot air for about 10/15 seconds, then it goes back to lukewarm. when i'm on the highway, the temp gauge never goes about 1/4 way or so, like it used to normally show, and i can get more hot air to flow in the car. when i was changing out the hoses, i was able to push water through the heater inlet and outlet holes...so the heater core is flowing...
not sure what to do!!!! any info/advice/help would be greatly appreciated...we just got our orders and will be moving to Ft. Lewis, WA in about a month, which we will be driving the 2100 miles from Texas, where we're currently stationed at....need this car in much better shape before then and we really can't afford to buy another car right now on a private first class's salary
bout ready to kill the car!!! :givebeer:
