1990 Nissan 240sx
KA24E
okay...... so i have been having ideing problems for a long time. good gas, NGK R plugs, new cap and rotor button, new plug wires(and coil wire).
Specifically the problem is after driving the car it takes a while to return to idle. i have tried adjusting the screw on the idle air control valve to tighten/loosen the spring, this does bring my idle up and down but it still does what i described before. i unplugged the lime green plug on the back of the unit and the car seems to be running perfect now - is there any harm to leaving this unplugged? from what i can see and from some of what i have read the idle air control valve only helps you start when the motor is cold.
Here are all my mods:
Stage 3 clutch ( 6 puck center sprung)
11.5 pound flywheel (stock is 22.5)
injen cold air intake( the long one)
cat removed (replaced with test pipe)
generic fart can type muffler ( it was on the car when i bought it)
Thanks - hopefully i can finally put this idle issue to bed. lol
KA24E
