Hi ppls.K im runnin a '90 s13 hatch with an RB20det,runs great and my setup is good,and Im ready to get LSD.Problem is,which one should I get?And what would work best in this car for the motor?I was set on getting the r32 lsd,then I found out that the r33 lsd would work just fine,it jus costs a lil more,so there was no reason to consider it until I found out the the Cefiros had r33 engines and LSD,and from what I understand the Cefiro lsd is the exact same as the r33 lsd,and I found a place where I can get a Cefiro lsd for only $100!(dont know about you guys but Im used to racing on a budget.) And when I switch out the dif do I jus swap out the pumpkin or do I use my pumpkin and change out the internals? I asked the same question on the 240sx forum and got mixed results..Im realy gettin a headache jus tryin to figure out what I should go with..
