There are four accumulator valves located above the valve body. Three of them have springs which rest on the valve body, and will fall out when the valve body is removed. The Factory Service Manual shows reassembly of the valve body to the trans with the trans out and upside-down. The springs are placed on the accumulator valves, and then the valve body is installed.
With the trans in the car, the springs will have to be placed in position on the valve body and the valve body carefully raised into position so as not to disturb them. Then the valve body will have to be held in place against the spring pressure while the attaching bolts are tightened. This will be a PIA.
There are two lengths of attaching bolts which must go in specific locations and tightened with a torque wrench to ~5.5 ft-lbs.
Here is a diagram from the FSM:
I suggest you download a Factory Service Manual from
www.phatg20.com You will have to join to get it.
Lew
