1 - 11 of 11 Posts
I know timing is different for each engine, but im trying to see how the advance curve is on other engines to see what i can do on mine.
I still couldnt get the advance curve of my one engine.
· Ex-mod/nissan guru
wath he mean would be : wath kind of ignition tuning is used on turbo car compared to n/a one.
well you still advance it (tuning wise) but way less and the advance goes down in the higher boost/high load (if im right)... the best way to do it would be on the dyno with the proper equipment/getting a mallory unit for the E16 (unsure if its still avail.) changing it on an vacuum unit would be to change the spring and related vacuum arm mechanism with lower movement and getting a higher initial advance... you would want to get a little higher than stock initial to compassate for lower compression and as the boost comes on/vacuum lowers you would get it to retard from the oem specs...
(someone correct me if im wrong)
· GA16DE
Thats the idea, but problem is to find a starting point for a blow through carb config
My turbo e16 will be ready next week, I am currenty running a fixed advance dist + carbs
The folks at http://autos.groups.yahoo.com/group/e15et/ posted some ignition parameters for ecus, I am starting from there on
Til yesterday I had 20 deg fixed advance, the car run great til 4000 rpm (90 oct gas), then its power curve fell like a rock
Last night I tried 15 deg fixed advance, now the car runs strongly til 5500 with a lil less quick response down
I will use this advance with the turbo, and keep an eye on my narrow band o2 sensor (too poor at the moment for a broad band unit) and my amplified mic to listen for pingin
· GA16DE
I am thinking to install a working vacuum advance to get some part throttle fuel economy
Good thing is the oem unit has a scre w to regulate how much vacuum advance you want/need before pingin occurs, and at boost there will be no vacuum advance at all :D
I am trying to oversimplify things to make this reliable, hope to get a turbo ecu, sensors, dist and wiring harness in a few months...
With "20 deg fixed advance" do you meen that the advance doesnt change and it stays at 20?
I was thinking about making some device with the vacuum advance taht will also retard when boost starts.
· GA16DE
Exactly
The weights inside the dist are assembled blocked/fixed in the 'open' position, without springs, as if it were at maximum advance
Dual diafragms systems seem too complicated and non reliable to me
A failure, some heavy pinging at 5000 rpm (7 psi) and say good bye to your turbo e16...
Regards
1 - 11 of 11 Posts
